Installation of SDK Pro on Linux Ubuntu
This section describes how to install Metavision SDK Pro on Linux Ubuntu 20.04 and 22.04 64-bit. Compilation on other versions of Ubuntu or other Linux distributions was not tested. For those platforms some adjustments to this guide or to the code itself may be required (specially for non-Debian Linux).
Metavision SDK Pro is our premium package giving access to the source code of all the SDK modules allowing you to customize the algorithms and compile on other platforms. Check our packaging page for more information and contact us for a quote if you are interested.
If you only need to have access to the source code of the Open modules (Base, Core, Core ML, Driver, UI, and HAL), compiling our open source project OpenEB will be enough. In that case, follow the specific guide on the Installation of OpenEB.
Table of Contents
Supported Cameras
Metavision SDK Pro contains the source code of the Prophesee camera plugin, enabling to stream data from our event-based cameras and to read recordings of event-based data. The supported cameras are:
If you want to use a Prophesee EVK that is not in the list above, it might have been discontinued. Refer to the Prophesee EVKs Support section to find out which previous version of the SDK is supporting it.
If you own a third-party vendor event-based camera, refer to the Camera Plugin Installation page to see how it can be deployed and configured.
Required Configuration
Please note the base system requirements for using Metavision SDK:
Operating system: Linux Ubuntu 20.04 or 22.04 64-bit
Architecture: amd64 (a.k.a. x64)
Graphic card: must support OpenGL 3.0 minimum
CPU: must support AVX2
To install the SDK on Windows, check the page Installation of SDK Pro on Windows.
Required Artifacts
To install Metavision SDK Pro on Linux, you will need the source code archives Prophesee delivered to you:
OpenEB:
metavision_open_x.y.z.tar
Advanced modules:
metavision_sdk_sources_cv_x.y.z.tar
,metavision_sdk_sources_analytics_x.y.z.tar
…Standalone applications:
metavision_sdk_sources_standalone_apps_x.y.z.tar
Upgrading Metavision
If you are upgrading Metavision from a previous version, you should first read carefully the Release Notes as some changes may impact your usage of our SDK (e.g. API updates) and cameras (e.g. firmware update might be necessary).
Then, you need to clean your system from previously installed Prophesee software. If after a previous compilation, you chose to
deploy the Metavision files in your system path, then go to the build
folder in the source code directory and
launch the following command to remove those files:
sudo make uninstall
In addition, remove Prophesee or Metavision folders and files in your system paths (/usr/include
, /usr/lib
, /usr/bin
, /usr/share
along with their /usr/local
equivalents) and in your environment variables (PATH
, PYTHONPATH
and LD_LIBRARY_PATH
Installing General Dependencies
Install the following dependencies:
sudo apt update
sudo apt -y install apt-utils build-essential software-properties-common wget unzip curl git cmake
sudo apt -y install libopencv-dev libboost-all-dev libusb-1.0-0-dev libprotobuf-dev protobuf-compiler libeigen3-dev
sudo apt -y install libhdf5-dev hdf5-tools libglew-dev libglfw3-dev libcanberra-gtk-module ffmpeg
Optionally, if you want to run the tests, you need to install Google Gtest and Gmock packages. For more details, see Google Test User Guide :
sudo apt -y install libgtest-dev libgmock-dev
For the Python API, you will need Python and some additional libraries. If Python is not available on your system, install it (we support Python 3.8 and 3.9 on Ubuntu 20.04 and Python 3.9 and 3.10 on Ubuntu 22.04). Then install some extra libraries:
sudo apt -y install python3-pip python3-distutils
sudo apt -y install python3.X-dev # where X is 8, 9 or 10 depending on your Python version (3.8, 3.9 or 3.10)
python3 -m pip install pip --upgrade
python3 -m pip install "opencv-python==4.5.5.64" "sk-video==1.1.10" "fire==0.4.0" "numpy==1.23.4" "h5py==3.7.0" pandas scipy
python3 -m pip install matplotlib "ipywidgets==7.6.5" pytest command_runner
You can use anaconda to install Python and
conda to manage your Python packages, but be sure to use a Python version that we support.
You will need to adapt the library installation steps accordingly and use conda
whenever we use pip
In addition, check that conda PYTHONPATH
contains /usr/lib/python3/dist-packages/
. If not, add it. For example with sys.path.append()
method of python module sys
import sys
print(sys.path)
# Add /usr/lib/python3/dist-packages/ to PYTHONPATH if the output of print(sys.path) does not mention it.
sys.path.append("/usr/lib/python3/dist-packages/")
In this documentation, we chose to use pip as a package manager. We recommend using it with virtualenv to avoid conflicts with other installed Python packages.
The Python bindings of the C++ API rely on the pybind11 library (version >= 2.6.0).
pybind11 is required only if you want to use the Python bindings of the C++ API. You can skip compiling these bindings by passing the argument -DCOMPILE_PYTHON3_BINDINGS=OFF during compilation (see step 3 of the compilation below). This allows you to skip installing pybind11, but you won’t be able to use our Python interface to the C++ API.
Unfortunately, there is no pre-compiled version of pybind11 available, so you need to install it manually:
wget https://github.com/pybind/pybind11/archive/v2.6.0.zip
unzip v2.6.0.zip
cd pybind11-2.6.0
cmake .. -DPYBIND11_TEST=OFF
cmake --build .
sudo cmake --build . --target install
Prerequisites for the CV module
To compile the XYT app from the CV sdk module. You’ll need to install Ogre3D, a graphic engine for 3D rendering.
From ubuntu 22.04:
sudo apt install libogre-1.12-dev libimgui-dev libfreetype-dev
On Ubuntu 20.04:
sudo add-apt-repository -y ppa:s-schmeisser/ogre-1.12
sudo apt install -y libogre-1.12
sudo apt install libogre-1.12-dev libimgui-dev libstb-dev libfreetype-dev
Prerequisites for the CV3D module
To use the CV3D module, you need to install a third-party Sophus library that is required to handle geometric transformation problems:
You need to install this archive version of Sophus:
https://github.com/strasdat/Sophus/archive/1.22.10.zip
Unzip and go to the Sophus directory:
unzip 1.22.10.zip cd Sophus-1.22.10 mkdir build && cd build
Compile and install:
cmake -DSOPHUS_USE_BASIC_LOGGING=ON .. cmake --build . --config Release sudo cmake --build . --target install
Prerequisites for the ML module
To use Machine Learning features, you need to install some additional dependencies. If you have some Nvidia hardware with GPUs, you can optionally install CUDA (11.6 or 11.7) and cuDNN to leverage them with PyTorch and LibTorch. Make sure that you install a version of CUDA that is compatible with your GPUs by checking Nvidia compatibility page.
Python Packages
You need to install PyTorch 1.13.1. Retrieve and execute the pip command of version 1.13.1 from the previous versions install guide section.
Then install some extra Python libraries:
python3 -m pip install "numba==0.56.3" "profilehooks==1.12.0" "pytorch_lightning==1.8.6" "tqdm==4.63.0" "kornia==0.6.8"
python3 -m pip install "llvmlite==0.39.1" "pycocotools==2.0.7" "seaborn==0.11.2" "torchmetrics==0.7.2" "pillow==9.3.0"
LibTorch for C++
To compile and run the neural network inference in a C++ pipeline, you need LibTorch (PyTorch’s C++ frontend)
Download the LibTorch version corresponding to your CUDA version (or take the CPU version if you don’t have CUDA):
Unzip the archive to a new folder LIBTORCH_DIR_PATH that you will reference when compiling the C++ inference sample. For example, for the CPU version:
unzip libtorch-cxx11-abi-shared-with-deps-1.13.1+cpu.zip -d LIBTORCH_DIR_PATH
LibTorch is delivered with a copy of libgtest libraries. Those should be removed to avoid conflicts:
rm LIBTORCH_DIR_PATH/libtorch/lib/libgtest.a rm LIBTORCH_DIR_PATH/libtorch/lib/libgtest_main.a
Prerequisites for standalone apps
To be able to compile Metavision Studio, you need to install NodeJS. You can either follow the full NodeJS install guide of execute the following commands:
sudo apt-get update
sudo apt-get install -y ca-certificates curl gnupg
sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
sudo apt-get update
sudo apt-get install nodejs -y
Preparation of the source code
First, extract the content of the archive metavision_open_x.y.z.tar
tar -xvf metavision_open_x.y.z.tar
This will create the folder openeb-x.y.z
containing OpenEB source code.
The absolute path to this directory is called MV_SDK_SRC_DIR
in the next sections.
Then extract the other SDK Pro archives in MV_SDK_SRC_DIR
tar -xvf metavision_sdk_sources_standalone_apps_x.y.z.tar -C <MV_SDK_SRC_DIR> tar -xvf metavision_sdk_sources_analytics_x.y.z.tar -C <MV_SDK_SRC_DIR> tar -xvf metavision_sdk_sources_calibration_x.y.z.tar -C <MV_SDK_SRC_DIR> tar -xvf metavision_sdk_sources_cv3d_x.y.z.tar -C <MV_SDK_SRC_DIR> tar -xvf metavision_sdk_sources_cv_x.y.z.tar -C <MV_SDK_SRC_DIR> tar -xvf metavision_sdk_sources_ml_x.y.z.tar -C <MV_SDK_SRC_DIR>
Compilation
To compile SDK Pro, now follow those steps:
open the
MV_SDK_SRC_DIR
directory
cd MV_SDK_SRC_DIR
Create and open the build directory
Generate the makefiles using CMake:
cmake .. -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DUSE_SOPHUS=ON -DUSE_TORCH=ON -DTorch_DIR=<LIBTORCH_DIR_PATH>/share/cmake/Torch/
you can adapt this command depending on the module you choose to install:
to skip the compilation of the CV3D module, remove the Sophus option
to skip the compilation of the ML module, remove the Torch options
If you want to specify to cmake which version of Python to consider, you should use the option
-DPython3_EXECUTABLE=<path_to_python_to_use>
. This is useful, for example, when you have a more recent version of Python than the ones we support installed on your system. In that case, cmake would select it and compilation might fail.
Compile:
cmake --build . --config Release -- -j `nproc`
Configuration and deployment
Once the compilation is done, you have two options: you can choose to work directly from the build
folder
or you can deploy the SDK files in the system path (/usr/local/lib
, /usr/local/include
Option 1 - working from
build
folder
To use the SDK directly from the
build
folder, you need to update some environment variables using this script (which you may add to your~/.bashrc
to make it permanent):source utils/scripts/setup_env.sh
Prophesee camera plugin is included in the SDK, but you still need to copy the udev rules files in the system path and reload them so that your camera is detected with this command:
sudo cp <MV_SDK_SRC_DIR>/hal_psee_plugins/resources/rules/*.rules /etc/udev/rules.d sudo udevadm control --reload-rules sudo udevadm triggerOption 2 - deploying in the system path
To deploy the SDK, launch the following command:
You can also deploy the SDK files (applications, samples, libraries etc.) in a directory of your choice by using the
CMAKE_INSTALL_PREFIX
variable (-DCMAKE_INSTALL_PREFIX=<METAVISION_INSTALL_DIR>
) when generating the makefiles in step 3 of the compilation. Similarly, you can configure the directory where the Python packages will be deployed using thePYTHON3_SITE_PACKAGES
variable (-DPYTHON3_SITE_PACKAGES=<PYTHON3_PACKAGES_INSTALL_DIR>
).you also need to update
LD_LIBRARY_PATH
andHDF5_PLUGIN_PATH
to make it permanent):export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib export HDF5_PLUGIN_PATH=$HDF5_PLUGIN_PATH:/usr/local/lib/hdf5/plugin # On Ubuntu 20.04 export HDF5_PLUGIN_PATH=$HDF5_PLUGIN_PATH:/usr/local/hdf5/lib/plugin # On Ubuntu 22.04
If you are using a third-party camera, you need to install the plugin provided
by the camera vendor and specify the location of the plugin using the MV_HAL_PLUGIN_PATH
environment variable.
Running tests
The more modules you add the more tests will be run when you do this step.
Go to this page and click on the
Download All
button to retrieve an archive of all the files necessary to run the tests. Please be aware that the archive you’ll receive is approximately 5 Gb in size.Extract and put the contents of this archive into
<MV_SDK_SRC_DIR>
. For instance, the correct path of sequence gen31_timer.raw should be <MV_SDK_SRC_DIR>/datasets/openeb/gen31_timer.raw.Regenerate the makefiles with the test options enabled:
cd <MV_SDK_SRC_DIR>/build cmake .. -DBUILD_TESTING=ON
Compile again:
Make sure you launched the
mentioned before, and run the test suite:ctest -C Release
You are now ready to use Metavision SDK. The best way to start getting familiar with the event-based technology is to open an event-based camera with Metavision Studio to begin data collection and visualization. You can choose to dive directly in the SDK by following a getting started guide or looking at a Code Sample.
